13 years agoDE0 with uClinux
Hi, cant configure device.expected jtag ip code 0x020f3000 for device, but found jtag id code is 0x020f2000.How resolve this problem. Kindly any help?
13 years agoIt should work. You may have made a mistake in the pin assignments,especially the clock signal. Use signaltap to see if you have valid clock and reset signals in your system.
