13 years agoDE0 with uClinux
Hi, cant configure device.expected jtag ip code 0x020f3000 for device, but found jtag id code is 0x020f2000.How resolve this problem. Kindly any help?
13 years agoThis seems to be enough. I would just add a system ID component to help you later if you have an inconsistency between your hardware and software configurations, but anyway the lack of system ID isn't the reason of your problem here.
Try and use signaltap to monitor the reset signal (remember, the reset input on a SOPC builder system is active low, not high) and the locked signal from the altpll_sys.
