11 years agoddr3 sdram controller (UniPHY) afi_half_clk doesn't work but status signals work fine
I have build a qsys system, that niosII connects a mm bridge then connects with ddr3 controller. I use afi_clk to drive the nios II. And then I export the afi_half_clk to external qsys to drive a cou...
11 years agoYes, via the "enable half rate clock" check box. I also enable the half rate configuration for the DDR2 controller.
