11 years agoDDR3 on Cyclone V E
Hi I would like to connect the MT41J128M16JT-125 with the uniPHY to my Cyclone V E as a hard memory interface. My clk_0 is 50MHz and the Systemclock is 80MHz. I connected the cmd and fifo...
11 years agoWhich fVCO is 300MHz? 300MHz is the minimum I can set on the DDR speed...
If I would like to run my Nios at 50MHz. Is it not posssible to have in this case a DDR3 RAM running with 300MHz in HardMemoryInterface? Or would it be possible with a DMA in between? What would the lowest NIOS frequency be, if I would like to habe the HardMemoryInterface?
