13 years agoDDR3 controller UNIPHY Creating an Avalon MM master
I have a Qsys system with a DDR3 UNIPHY controller instantiated and it works. I can read and write from Nios and I can use a DMA engine to pull data and stream it over the ethernet. But I am ...
13 years agoAddress is 32bit wide,but addr[31] is a cache flag.so there is just 2G byte in avalon bus that you can access. when addr[31] is 1,it means no cache access.
