15 years agoDDR2 SDRAM max buffer lenght
Hi, I'm a beginner with Nios programming and I have following issue. I'm using a DDR2 SDRAM Controller in my SOPC System and I got the description: 333,333MHz, 128MB, 32 bits wide, Descrete Dev...
15 years agoIf you are using the altera functions, then alt_uncached alloc() will do something like the required action.
I suspect it might not ensure that the buffer start/end do not share a cache line with any other data, nor that the cache doesn't contain anything for the returned address range.
