15 years agoDDR2 SDRAM max buffer lenght
Hi, I'm a beginner with Nios programming and I have following issue. I'm using a DDR2 SDRAM Controller in my SOPC System and I got the description: 333,333MHz, 128MB, 32 bits wide, Descrete Dev...
15 years agoNo one else can know - since it depends on exactly what else you have loaded.
You probably also want to ensure the buffer is cache line aligned. If you are allocating in in you C something like: umsigned char dma_buffer[BUFfER_SIZE] __attribute__((aligned(32))); will ensure the buffer ends don't cross cache line boundaries.
