14 years agoDDR2 and Ethernet
Hi friends,
I want to control DDR2 and Ethernet with NIOS II on my board. ADC results are read from LVDS_rx module and store on DDR2 and then stream out via Ethernet. On my board, there is no SDRAM except for a DDR2, so I want to use on-chip memory for Nios ii . Can I get it? Any advice and guidance will be appreciated.13 Replies
Sure, why not. If You'll use SGDMA, then You can allocate memory using malloc() or use fixed value.
OK,I'll try it. Thank you!
I'm not sure what the minimum M9K footprint for a nios cpu is, but it is relatively small!
- 1 M9K for the registers - Remove the dynamic branch prediction logic (this is a 'hidden' option) - Read code from tightly coupled memory - No data cache, data can be in the same M9K as the code - No JTAG debug - Boot directly from the instruction memory (no separate M9K for epcs (etc) boot) - Write small, tight code without any libc bloat and with minimal wrapper layers.
