14 years agoDDR2 and Ethernet
Hi friends, I want to control DDR2 and Ethernet with NIOS II on my board. ADC results are read from LVDS_rx module and store on DDR2 and then stream out via Ethernet. On my board, there is no...
14 years agoI'm not sure what the minimum M9K footprint for a nios cpu is, but it is relatively small!
- 1 M9K for the registers - Remove the dynamic branch prediction logic (this is a 'hidden' option) - Read code from tightly coupled memory - No data cache, data can be in the same M9K as the code - No JTAG debug - Boot directly from the instruction memory (no separate M9K for epcs (etc) boot) - Write small, tight code without any libc bloat and with minimal wrapper layers.
