20 years agoDDR2 & Cyclone II EP2C8
edit: to be clear, i mostly want to know: has anyone used ddr2 with an ep2c8 speed grade 8? I am currently evaluating the possibility of using DDR2 memory, one device with x16 bit wide bus run...
20 years ago --- Quote Start --- originally posted by mgilroy@Oct 9 2006, 02:10 PM any update on how to fix this?
i've the same problem on a cyclone ii dev board.
i've instantiated the design via sopc builder and synthesis fails due to "ddio output nodes could not be placed by the fitter"
renaming the ddr_sdram_0 in sopc builder to ddr_sdram without the trailing "_0" did not fix the problem
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18603)
--- quote end ---
--- Quote End --- you SHOULD! name the DDR ddr_sdram_0, this was my point (nad NOT! without _0) you have a different problem, maybe you did not place the DDR signals to dedicated pins, compare the .qsf file of your project with the .qsf file of the Altera development board, check for: - IO block power supplies - if DDR pins are SSTL (this should be done automatically by SOPC builder) if you find it easier you may use the assignment editor IzI
