20 years agoDDR2 & Cyclone II EP2C8
edit: to be clear, i mostly want to know: has anyone used ddr2 with an ep2c8 speed grade 8? I am currently evaluating the possibility of using DDR2 memory, one device with x16 bit wide bus run...
20 years ago --- Quote Start --- originally posted by bigboss25@Oct 9 2006, 09:45 AM hi iztok,
i have 2 questions:
- what package are you using (tqfp, bga ?)
- what is the targetted clock frequency ?
regards.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18599)
--- quote end ---
--- Quote End --- We did not have a clear target, but I was able to compile a project without DMA at: - CPU 60MHz (it may work at up to 75MHz) - DDR 110MHz I tried to compile a very minimal project (only cpu, ddr, uart) with a common CPU and DDR clock, the minimum frequency for the DDR is about 85MHz and I was able to compile the whole system at 87MHz (as far as I remember). But we did not conduct any tests we probably will. IzI
