20 years agoDDR2 & Cyclone II EP2C8
edit: to be clear, i mostly want to know: has anyone used ddr2 with an ep2c8 speed grade 8? I am currently evaluating the possibility of using DDR2 memory, one device with x16 bit wide bus run...
20 years agoThis might be a bug in the DDR/DDR2 SOPC component, I had similar problems with DDR. Use the default name for the instantiated component in sopc builder. I think it is:
ddr_sdram_0 the trailing _0 was the problem on my design. Iztok Jeras
