21 years agoDDR vs. SDR RAM...
Anyone know if DDR Ram will fare better with the NiosII data master than SDRAM? After Dirk figured out it takes a whopping 12 clocks @50MHz (~240ns) per SDRAM read when not using the dma, we re...
21 years agoHi James,
Can you elaborate on NiosII/f SDRAM access? Jesse indicated the largest part of the problem was that the NiosII/f data master was not "Latency Aware". So anything not dma'd or read out of the cache incurs a large timing hit as demonstrated in the other thread on this topic -even if the reads are back to back in the same bank. A work around or a glimpse of the roadmap would sure be welcome. Thanks, Ken
