11 years agoData transfer between fpga (14 bits) vhdl block to NIos II system (16 bits)
Hi, I am writing C code to program Altera Nios II system in Cyclone IV E. The Nios II system is used to control some custom FPGA blocks written in VHDL in Quartus II. In the vhdl block ...
11 years agoOk, I thought I should make it simpler:
From vhdl, the data is the input to Nios.data <= to_slv(resize(scale*to_sfixed(in, 0, -11), 9, -6));
"scale" is any number to represent the peak value, "in" is a sinusoidal waveform. "data" is the input to the Nios II. In the C code, initially, I read the data from vhdl block using the C code below: alt_16 data=0;
data = IORD_ALTERA_AVALON_PIO_DATA(data_base); After this, the Nios system do some calculation (multiply with "a" for instance, where a is not a constant depending on calculation on some other inputs) to give a new value of "data", say name it as "data_new". data_new=(data)*(a); After the calculation, I want to assign "data_new" back to another custom block in vhdl say "block b". Finally, I write the "data_new" back to another custom block in vhdl say "block b". IOWR_ALTERA_AVALON_PIO_DATA(data_new_base, data_new); I am not getting the correct value of "data_new" fed to the fpga, what could be the causes? timing issue? clock? What aspects can I look into?
