12 years agoData Exchange between FPGA and NIOS2
Hi Everyone, I want to implement data exchange between NIOS2 and FPGA . For exampe, transfer data form NIOS2 to FPGA with a Dual Port RAM. Is it possible to do that ? and how to make that happe...
12 years agodid you see the picture I posted in my above reply?
when you export the 's2' port to my nios II qsys top level, you will get .dpram_s2_address(exchange_addr), // dpram_s2.address .dpram_clk2_clk(CLK_100M), // dpram_clk2.clk .dpram_s2_chipselect(1'b1), // .chipselect .dpram_s2_clken(1'b1), // .clken .dpram_s2_readdata(exchange_rdata), // .readdata .dpram_s2_write(exchange_wren), // .write .dpram_s2_writedata(exchange_wdata), // .writedata then you can write or read directly to the Dual Port RAM no other timing logic needed , only pay attention that 'exchagne_wren' must be set to 1'b1 when write data is needed. 'chipselect' and 'clken' must also be set with 1'b1. keep contact with me if there is futher problem with this issue. good luck!
