21 years agoData Cache
I was looking at the documentation, and found that address bit 31 is used to determine cache and non-cachable memory. When bit 31 is low is the memory/IO cachable, or is it non-cachable? Didn't...
21 years agoBit 31 set (logic-1) bypasses cache.
IORD/IOWR on any address (bit 31 set or not) also bypasses cache. Mallocing a buffer with the 'uncached' malloc provided with the HAL will give you a buffer that also bypasses cache.
