21 years agoData bus sharing and user component with HDL files
Hi all, When I create a new tristate slave component for the NIOS/SOPC builder and the component is implemented using some custom logic in VHDL code, the SOPC builder adds a new data bus for th...
21 years agoBeing out of work for several days, so...
Hi, Kelvin, Mike, I have manually edited the PTF file (making sure that neither SOPCBuilder nor QuartusII were running) and changed the component's PORT data attribute is_shared to "0"; same results as with value "1", an extra data bus appeared. In the settings for the tri-state bus master I found no is_shared attribute to play with. Where is the "tristate bus" located, Kelvin? Thanks in advance.
