21 years agoData bus sharing and user component with HDL files
Hi all, When I create a new tristate slave component for the NIOS/SOPC builder and the component is implemented using some custom logic in VHDL code, the SOPC builder adds a new data bus for th...
21 years agoHi Vlorenzo
There seems to be a bug in the SOPC builder. To work around this problem, you will have to manually edit the ptf file and set the "is_shared" value to is_shared = "0" for the tristate bus and regenerate the SOPC system. This should solve your problem. Regards, Kel
