16 years agoCyclone4 NIOS can only run at 60M?
hi every one; first using niosii , with the demo board"civgx_trans_starter_board" which is EP4CGX15BF14; using the example"bts_general" offered by the kit, this example contains"TSE/SSRAM/FL...
16 years agoYou're wrong, pipelining does increase fmax a lot, when you put them at the right place. I don't know if there is any documentation about the fmax of a Nios setup, because it depends a lot on the configuration.
On Cyclone III it is very easy to reach 100MHz, and with some care 120MHz shouldn't be a problem. I never tried to get over that. Have a look at the SOPC builder log during generation, I think it says which core(s) don't have a license.
