16 years agoCyclone4 NIOS can only run at 60M?
hi every one; first using niosii , with the demo board"civgx_trans_starter_board" which is EP4CGX15BF14; using the example"bts_general" offered by the kit, this example contains"TSE/SSRAM/FL...
16 years agoYou can add Avalon MM pipeline bridges to increase the fmax. You could put one between the SGDMA masters and the RAM, as an example. Another one before the JTAG debug module in the CPU usually helps too.
