Cyclone V does not boot from S25FL128 if SOF2FLASH is used
- 1 year ago
I've actually found the problem.
The issue was that sof2flash utility could not generate proper srec file. Either the little-endian format was wrong or there were wrong bytes in header area.
To resolve this issue I used a third party utility https://sourceforge.net/projects/srecord/ to convert .rbf file into .flash
The command line for this is
srec_cat file.rbf -Binary −Bit_Reverse -Output=file.flash-Binary option specifies that input file has binary format
and
- Bit_Reverse option specifies reversing bits in output file.
With this command a proper .flash file can be generated, which then can be programmed using nios2-flash-programmer or quartus_pgm into Flash.
Hi
It seems like it is more of the override file that is having the problem.
It is best to consult Cypress on the changes required for the override file.
Jingyang, Teh
