syoma
1 year agoCyclone V does not boot from S25FL128 if SOF2FLASH is used
Hi all I need some hint: We are using Cypress/Infineon S25FL128 as configuration flash for Intel Cyclone V FPGA. I use Quartus 17.0 Lite. I created a simple Flash Programmer Project using "Nios® I...
- 1 year ago
I've actually found the problem.
The issue was that sof2flash utility could not generate proper srec file. Either the little-endian format was wrong or there were wrong bytes in header area.
To resolve this issue I used a third party utility https://sourceforge.net/projects/srecord/ to convert .rbf file into .flash
The command line for this is
srec_cat file.rbf -Binary −Bit_Reverse -Output=file.flash-Binary option specifies that input file has binary format
and
- Bit_Reverse option specifies reversing bits in output file.
With this command a proper .flash file can be generated, which then can be programmed using nios2-flash-programmer or quartus_pgm into Flash.
tehjingy_Altera
1 year agoHi
Could you try out the values as suggested from the document?
Jingyang, Teh
syoma
1 year agoYes, they didn't work
