11 years ago
Cyclone V Dev Board - Problem using sopc2dts
Thanks in Advance.
We are using Qsys/Quarturs 14.1.
Our linux release is Poky 8.0 - Linux version 3.9.0
We have taken the GSRD for the Cyclone V and added to the design a 16550 serial port on the HSMC connector.
Then I have taken the generated *.sopcinfo to create the new *.dtb file utilizing the following command:
sopc2dts --input gsrd_modified.sopcinfo
--output socfpga.dtb
--type dtb
--board soc_system_board_info.xml
--bridge-removal all
--clocks
I then replace the original *.dtb file with the newly created *.dtb file on the microSD card.
While booting I get some WARNING messages with traces and the final message with a trace is:
Unable to handle kernel paging at virtual address c08d400c
Internal error: Oops: 807 [#1] SMP ARM
I am enclosing the complete boot message.
Am I doing something wrong in creating the *.dtb file?
Is there a later kernel version I should be using?
    Hi, follow the rules at this page:
    www.alterawiki.com/wiki/sopc2dts in the section "Module and Interface Assignments in hw.tcl Influencing Sopc2dts"
    It seems that you did not setup your _hw.tcl for your custom ip components.
    regards
    --- Quote Start ---
    I am working on Cyclon V soc kit,I want to generate .dts from sopcinfo file.I am not using GHRD design(that is prepared by altera).I am workng on my design in which I have added my custom IP core in qsys system.
    My issue is how ca I prepare sos_system_board_info.xml and hps_clock_info.xml ??
    what I run this command without these .xml file I got following message.
    command:
    $ sopc2dts --input soc_system.sopcinfo
    --output socfpga.dts
    --board hps_clock_info.xml
    message :
    Exception occurred: use -v for more information
    Component i2c_master of class sls_avalon_i2c_m is unknown
    Component video_data_stream of class video_data_stream is unknown
    Please let me know if you have any idea about ,how to prepare xml files.
    --- Quote End ---
    You did not assign the correct Module and Interface Assignments in the _hw.tcl of you custom ip
    regards
    Hi meds7,
    This is a part of my .dts file:
    in that my module is ''vidoe data stream' ,other modules mentioned with compitible options and my modules is with unknown ,but I can't find any option in .tcl that represents compatible option.one more thins is ,this is my custom module so it doesn't have compatible options in that.
    jtag_uart: serial@0x20000 {
    compatible = "altr,juart-14.1", "altr,juart-1.0";
    reg = <0x00020000 0x00000008>;
    interrupt-parent = <&hps_0_arm_gic_0>;
    interrupts = <0 42 4>;
    }; //end serial@0x20000 (jtag_uart)
    video_data_stream_0: unknown@0x30040 {
    compatible = "unknown,unknown-1.0";
    reg = <0x00030040 0x00000040>;
    }; //end unknown@0x30040 (video_data_stream_0)
    sysid_qsys: sysid@0x10000 {
    compatible = "altr,sysid-14.1", "altr,sysid-1.0";
    reg = <0x00010000 0x00000008>;
    id = <2899645456>; /* embeddedsw.dts.params.id type NUMBER */
    timestamp = <1437468644>; /* embeddedsw.dts.params.timestamp type NUMBER */
    }; //end sysid@0x10000 (sysid_qsys)
    Let me know if you have any idea about that.
    Thanks for reply.
    --- Quote Start ---
    Hi meds7,
    Thanks for reply.
    --- Quote End ---
    Hi, I mean the _hw.tcl file that belongs to your custom ip component. You said you designed several custom Avalon components which you instantiate in your Qsys design. You need to setup a _hw.tcl file for your component where you should define some settings.
    Please have a look at this page;
    http://www.alterawiki.com/wiki/sopc2dts under section Module and Interface Assignments in hw.tcl Influencing Sopc2dts
    --- Quote Start ---
    Hi meds7,
    Thanks for reply.
    --- Quote End ---
    You said you made some custom ip components that you use in Qsys. When you did that you needed to create a corresponding _hw.tcl file.
    That one seems to miss some essential Module and Interface Assignments..
    Look at the altera wiki for :
    [h=2]Module and Interface Assignments in hw.tcl Influencing Sopc2dts[/h]
    Also have a look at the "Creating Qsys Components" chapter of the quartus II handbook. In the latest version 15.0 it is chapter 6. There you see the _hw.tcl for you custom component defined. On the wiki that I showed you additional info is found on additional module assignments that influence the creation of your .dts file after you feed it to sopc2tds.
    regards
