11 years agoCyclone V Dev Board - Problem using sopc2dts
Thanks in Advance. We are using Qsys/Quarturs 14.1. Our linux release is Poky 8.0 - Linux version 3.9.0 We have taken the GSRD for the Cyclone V and added to the design a 16550 serial p...
11 years ago --- Quote Start --- Hi meds7, This is a part of my .dts file: in that my module is ''vidoe data stream' ,other modules mentioned with compitible options and my modules is with unknown ,but I can't find any option in .tcl that represents compatible option.one more thins is ,this is my custom module so it doesn't have compatible options in that. //===================================== jtag_uart: serial@0x20000 { compatible = "altr,juart-14.1", "altr,juart-1.0"; reg = <0x00020000 0x00000008>; interrupt-parent = <&hps_0_arm_gic_0>; interrupts = <0 42 4>; }; //end serial@0x20000 (jtag_uart) video_data_stream_0: unknown@0x30040 { compatible = "unknown,unknown-1.0"; reg = <0x00030040 0x00000040>; }; //end unknown@0x30040 (video_data_stream_0) sysid_qsys: sysid@0x10000 { compatible = "altr,sysid-14.1", "altr,sysid-1.0"; reg = <0x00010000 0x00000008>; id = <2899645456>; /* embeddedsw.dts.params.id type NUMBER */ timestamp = <1437468644>; /* embeddedsw.dts.params.timestamp type NUMBER */ }; //end sysid@0x10000 (sysid_qsys) //===================================== Let me know if you have any idea about that. Thanks for reply. --- Quote End --- You said you made some custom ip components that you use in Qsys. When you did that you needed to create a corresponding _hw.tcl file. That one seems to miss some essential Module and Interface Assignments.. Look at the altera wiki for : [h=2]Module and Interface Assignments in hw.tcl Influencing Sopc2dts[/h]
