11 years agoCyclone V Dev Board - Problem using sopc2dts
Thanks in Advance. We are using Qsys/Quarturs 14.1. Our linux release is Poky 8.0 - Linux version 3.9.0 We have taken the GSRD for the Cyclone V and added to the design a 16550 serial p...
11 years ago --- Quote Start --- Hi, Can you tell me what your issue was? In the meantime I have been able to succesfully get it work with the 13.1 tools. I will try the 14.1 tools. Btw, I believe that the most tricky part will be the correct setting up of the board info.xml for generating the .dts file. With the ghrd that info is already avalaible but i expect more difficulties when expanding the ghrd system with own ip components. regards --- Quote End --- My issue was that the Quartus 14.1 generated *.rbf file was compressed (2.2 MB) while the corresponding *.sof was approximately 7.0 MB. This is done in the "File-Convert file..." as per the instructions on one of the Rocketboard pages. So, when I used the uncompressed version and replaced that *.rbf file on the SD card. It booted fine. Today I'll be trying our design which is the Golden design with the IP 16550 off of the HMCS connector. I don't believe I need to change the board_info file for this. I think the sopcinfo will map this to the HMCS connector that should already be a part of the board_info. I will post what I find if you are interested. Let me know. I'm heading to the LAB now.
