11 years agoCyclone V Dev Board - Problem using sopc2dts
Thanks in Advance. We are using Qsys/Quarturs 14.1. Our linux release is Poky 8.0 - Linux version 3.9.0 We have taken the GSRD for the Cyclone V and added to the design a 16550 serial p...
11 years ago --- Quote Start --- UNCOMPRESSED *.rbf file WORKS!! I hope this helps others. There are so many details. I generated the *.rbf file from Qsys/Quartus 14.1 I'll now see about adding what I need to the Linux kernel (serial support)- see that that works (I've done that before). When that works then I'll go to our new Cyclone V design that adds the serial port and generate the *.dtb file and *.rbf that go with that design. --- Quote End --- Hi, Can you tell me what your issue was? In the meantime I have been able to succesfully get it work with the 13.1 tools. I will try the 14.1 tools. Btw, I believe that the most tricky part will be the correct setting up of the board info.xml for generating the .dts file. With the ghrd that info is already avalaible but i expect more difficulties when expanding the ghrd system with own ip components. regards
