11 years agoCyclone V Dev Board - Problem using sopc2dts
Thanks in Advance. We are using Qsys/Quarturs 14.1. Our linux release is Poky 8.0 - Linux version 3.9.0 We have taken the GSRD for the Cyclone V and added to the design a 16550 serial p...
11 years agoHi, I think that it has to do with the generation of the .rbf file which is uncompressed when you just follow the instructions. Did you note the difference of the filesize of the original raw binary and the newly generated one? If you click on properties when you added the sof image then you'll find a checkbox to enable compression. Let me know if that helps...
