13 years agoCyclone IV GX Transceiver Starter Kit nterface with ADC module
I wonder who has done a project that interface the Cyclone IV GX transceiver starter kit with an ADC module. I need an ADC module having sampling frequency up to at least 20Mhz. What should I conside...
13 years ago --- Quote Start --- I'm planning to use an ADC to sample a signal with 10Mhz frequency and then transmit it to Cyclone IV. --- Quote End --- how are you planning on transmitting the samples? If the ADC outputs 16-bit samples, then you would need 16 bits of I/O. The Cyclone IV starter kit does not have much I/O, so I'm not sure you will be able to use it. --- Quote Start --- Do you mean JESD204A has PCIe connector and I need a PCIe-to-SMA breakout cable to connect it with Cyclone IV? I see the Cyclone IV has both a SMA connector (if I do not misunderstand it) and a PCIe. --- Quote End --- JESD204 defines a protocol for transmitting the ADC data using high-speed transceivers. http://www.eetimes.com/design/analog-design/4371745/an-overview-of-the-jesd204-standard-for-analog-digital-converters It is up to you to figure out how to get the data from the ADC to the Cyclone IV GX board. If you were going to design your own board, then you could plug the Cyclone IV GX PCIe connector into your board. However, if you were going to go to that much trouble, you may as well put the FPGA on the board too. At this point you haven't really described enough detail to provide help. Cheers, Dave
