16 years agoCyclone IV E remote update +epcs+cfi_flash
hi all,i want to use epcs and cfi_flash to switch applications. my firmware and software are stored in sd card. 1. read application's firmware from sd card ,then write epcs. (i have converte...
16 years agothe problem has been solved!
In my c code, I use 'alt_write_flash_block ' API. my flash is 8M , consist of two regions. region0's block_size is 8192-bytes; region1's block_size is 65536-bytes; in the past, i operate region0 and region1 with 65536-bytes, so the error like my description occur. The right method should be: operate region0 with 8192-bytes; operate region1 with 65536-bytes; That's all, thank you!
