13 years agoCyclone III Configuration Advice Required...
Hi All, I am just about to start the design & layout for my first CYCLONE III based board using the EP3C10E144C8N device. I have read a good deal on the EPCS app notes but would like some feedb...
13 years ago --- Quote Start --- Another thought occured to me. I would like to be able to use the serial flash device to store lookup tables that are used and updated in the program. I assume that this would be possible in one serial flash (if suffieciently large) such that I can: 1) Configure FPGA 2) Load NIOS code into SDRAM 3) Store lookup tables for use by main program. I would imgaine that as long as I make sure that I dont overwrite the config and C prgram it should be OK? --- Quote End --- Yes, this will work fine. I'm planning on putting a Spansion S25FL512S device on a board I am working on. Its not an officially supported AS device, however, the serial flash command codes are identical. The device can be configured to operate in Quad-SPI mode, so once the Cyclone IV E has configured, I will be able to access the flash much faster for reads (writes involve 'programming' delays, so the Quad nature is not as much of a benefit there). Cheers, Dave
