13 years agoCyclone III Configuration Advice Required...
Hi All, I am just about to start the design & layout for my first CYCLONE III based board using the EP3C10E144C8N device. I have read a good deal on the EPCS app notes but would like some feedb...
13 years agoHi Dave,
Another thought occured to me. I would like to be able to use the serial flash device to store lookup tables that are used and updated in the program. I assume that this would be possible in one serial flash (if suffieciently large) such that I can: 1) Configure FPGA 2) Load NIOS code into SDRAM 3) Store lookup tables for use by main program. I would imgaine that as long as I make sure that I dont overwrite the config and C prgram it should be OK? What do you think? D
