21 years agocyclone ep1c6Q connects to 5V PCI
In my design, I want to use bank 4 of ep1c6q240 to connect 5V pci. Must i use buffers between ep1c6 and 5V pci, including AD[31:0] , CLK, control signals? If so, what kind of buffer chips should use and how to buffer?
If anyone have an example?5 Replies
try to use IDTQS3861...
eRen,
inserting buffers is not recommended. ... see altera application note an330.pdf (http://www.altera.com/literature/an/an330.pdf) But in actual hardware no PCI master drives the bus with 5V. Since years there is a migration to 3.3V in progress. Normally 'PCI universal cards' (with two keying slots) accept 5V but drive 3.3V, because PCI 3.0 removes support for 5V-only cards. ... see pci faq (http://www.pcisig.com/news_room/faqs/faq_pci30/pci30_faq.pdf) Mike - Altera_Forum
Altera used the QS3861 (as per Camelot).
Refer to this link for the datasheet for the Stratix PCI board. (The schematic is embedded in this PDF doc) stratix pci development board datasheet (http://www.altera.com/literature/ds/ds_stratix_pci_bd.pdf) - Altera_Forum
Thanks very much. I will try. eRen - Altera_Forum
I have read the files, but still have questions. My pci add in card will be connected to PC motherboard. The PCI connector on common PC motherboard does not have the 3.3V PCI keys, so I think using buffers is better. If having used buffers, which bank of EP1C6Q244 shall I use, bank1,3(with 3.3V PCI support) or bank 2, 4(without 3.3V PCI surpport, just 3.3V TTL)? The PCI CLK length is 2.5inches. If using buffer chips, it means that the wire between PCI CLK pin and buffer chip is 2.5inches, or from PCIpin to EP1c6Q pin is 2.5inches? Thanks, eRen
