16 years agoCyclone 2 issue with ethernet
Hi all. I have been searching and searching and hope I either have a simple problem that I am over looking or just somehow missed the one thing that would have helped. I am more or less brand ...
16 years agoCorrection: I did get past this problem. A .sof file was in the folder with all of the files from my project in Nios. I copied the DE2_WEB folder into a different folder to make all of my changes on, that way if I screwed up bad everything would still be ok in a different location. When I use the .sof file from the original folder I do not get the dtrap error at all, instead I get
--- Quote Start --- nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) --- Quote End --- And then nothing happens on the board or the terminal.
