16 years agoCyclone 2 issue with ethernet
Hi all. I have been searching and searching and hope I either have a simple problem that I am over looking or just somehow missed the one thing that would have helped. I am more or less brand ...
16 years ago --- Quote Start --- which board are you using? DE2? Which Ethernet Hardware ist on the board (Phy, MAC)? Are you using the TSE MAC from Altera? It seems that the webserver program doesn't correct initialize the device driver for Iniche stack. May be it's not compatible to the NiosII version 9.1. Compare this with the already running socket server example. Is the socket server example based on Iniche stack? Are you using ucosII? Could you provide the Hardware desing as .qar file and the corresponding software projects (socke server, webserver)? Jens --- Quote End --- Sorry for the long delay in replying to your response, it is my last semester as an undergrad and last week and most of this week was spent working on group projects and exams. I am using an Altera DE2 board (Cyclone II). The socket server example had no iniche files in Nios when I ran it, so I believe it is not based off of the Iniche stack? I have the Quartus II project file (.qar file) for the DE2_web program I am trying to get to work, but do not have anything similar for the socket example. The example only had software on the NIOS end (got it off of the CD that came along with the FPGA). I am very sorry if my responses here seem vague or completely useless, I am completely new to this FPGA and have had very little experience with FPGAs in the past (worked with a Digilent Basys 2 board a bit last semester, but only used schematic capture tools)
