16 years agoCyclone 2 issue with ethernet
Hi all. I have been searching and searching and hope I either have a simple problem that I am over looking or just somehow missed the one thing that would have helped. I am more or less brand ...
16 years agowhich board are you using? DE2? Which Ethernet Hardware ist on the board (Phy, MAC)? Are you using the TSE MAC from Altera?
It seems that the webserver program doesn't correct initialize the device driver for Iniche stack. May be it's not compatible to the NiosII version 9.1. Compare this with the already running socket server example. Is the socket server example based on Iniche stack? Are you using ucosII? Could you provide the Hardware desing as .qar file and the corresponding software projects (socke server, webserver)? Jens
