Cyclone 10 GX Nios V Ethernet Ping Issue - UC/TCP-IP Error 20012 and TSE/mSGDMA Debugging ;
- 1 month ago
Hello JL,
Thank you for the explanation and helping in the debugging process.
I am happy to inform you that I have now successfully resolved the issue and can ping the Cyclone 10 GX board with Nios 5 processor successfully.
After further debugging, I found that the issue was not related to the OS_MAX_EVENTS size or event pool depth. The actual issue was related to the network configuration and the initialization sequence of the DHCP server. After correcting the network configuration and ensuring proper initialization, the ping functionality started working successfully.
Thank you again for your time, support, and helpful suggestions
Best regards, Chandan H M
Hello JL,
Thanks for sharing your solution, Chandan! That helps the rest of the community.
Sue
