21 years agocustom uClibc problems
Hi people I have followed the tutorial from microtronixs on how to build a custom uClibc library. After I have run the menuconfig I then begin the make from the toplevel makefile. It compiles for so...
21 years agoHmm... sounds like the Make process couldn't find the autoconf file that's generated during the building of a linux kernel.
Things to confirm: - Double check the Linux Build Location option in the uClibc menuconfig. It should point to a kernel project build directory, not to the linux source tree. - The kernel project that's specified within the uClibc menuconfig must be built at least once to generate the autoconf.h file - After building the kernel, does an autoconf.h file exist inside the build directory? I think it should be in <kernel_project>/build/include/linux Hope that helps, if not let me know and I'll dig a bit deeper.
