16 years agoCustom sram memory not usable in NiosII IDE
Hello guys I just created a toyboard using a CycloneIII (EP3C5), a 2Mbytes 16bits flash memory, a 2Mbytes 16 bits sram memory, a 50Mhz oscillator, some voltage regulators and a couple of connec...
16 years agoThank you for your quick answer. My problem is now solved.
After your solution I discovered that on the tab Interfaces of Component Editor there is an option called "Show deprecated parameter". Checking this option enables to see parameters like "Non-volatile storage" and "Memory device". https://www.alteraforum.com/forum/attachment.php?attachmentid=1653 Best regards Márcio
