16 years agoCustom sram memory not usable in NiosII IDE
Hello guys I just created a toyboard using a CycloneIII (EP3C5), a 2Mbytes 16bits flash memory, a 2Mbytes 16 bits sram memory, a 50Mhz oscillator, some voltage regulators and a couple of connec...
16 years agoYou need to activate a special property to tell that your component is a memory device.
I assume that you used the component editor and that it created a *hw.tcl file to describe it. Open that file and look for a section describing the avalon interface:add_interface s1 * *look for a line like this:set_interface_property s1 isMemoryDevice false and change it to:set_interface_property s1 isMemoryDevice true
