14 years ago
Custom Linker Script
Dear all,
I have to add an output section in the final binary called "EXTSec". Therefore, I modified the makefile to point to a linkerscript.lds. Then I copied the original likerscript.x contents, which is located in ./bsp folder, and pasted it into my linkerscript.lds. After that, I added the following output section
.EXTsec :
./obj/CRT1.o
} > SDRAM
As a result, I got the following error
./obj/CRT1.o: In function `Task_CRT1':
multiple definition of `Task_CRT1'
obj/CRT1.o CRT1.c:19: first defined here
collect2: ld returned 1 exit status
make: ***[App.elf] Error 1
I need to put all input sections in that object file at the same output section contiguously.
