12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
11 years agoWhen either of you run into this issue is there any components between the master and slave like bridges by any chance? Likewise is the master and slave at different levels of the heirarchy? The reason why I'm asking about masters and slaves is because interrupts are tied to MM interfaces so this information might help find the culprit.
