12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoI have run into the same problem with my project in Quartus 13.1. I have two instances of a custom component in my design, and the interrupts are set to -1 in the system.h file. When I first checked the _hw.tcl file, the associatedAddressablePoint was blank. I had used the default "interrupt_sender" name in the component, so I renamed it. After I regenerated the component with this change, the associatedAddressablePoint was set as follows:
# # connection point AD9637_irq_sender# add_interface AD9637_irq_sender interrupt end set_interface_property AD9637_irq_sender associatedAddressablePoint AD9637_irq_sender set_interface_property AD9637_irq_sender associatedClock adc_clk set_interface_property AD9637_irq_sender associatedReset reset set_interface_property AD9637_irq_sender ENABLED true set_interface_property AD9637_irq_sender EXPORT_OF "" set_interface_property AD9637_irq_sender PORT_NAME_MAP "" set_interface_property AD9637_irq_sender CMSIS_SVD_VARIABLES "" set_interface_property AD9637_irq_sender SVD_ADDRESS_GROUP "" add_interface_port AD9637_irq_sender ad9637_irq irq Output 1 I then fully replaced the components in qsys and verified that the interrupt sender name changed on the component. I assigned the IRQ in qsys and re-generated the design and the BSP for the Nios. However, I still do not see the interrupt in system.h: /* * AD9637_interface_0 configuration * */ # define AD9637_INTERFACE_0_BASE 0x1000# define AD9637_INTERFACE_0_IRQ -1# define AD9637_INTERFACE_0_IRQ_INTERRUPT_CONTROLLER_ID -1# define AD9637_INTERFACE_0_NAME "/dev/AD9637_interface_0"# define AD9637_INTERFACE_0_SPAN 1024# define AD9637_INTERFACE_0_TYPE "AD9637_interface"# define ALT_MODULE_CLASS_AD9637_interface_0 AD9637_interface /* * AD9637_interface_1 configuration * */ # define AD9637_INTERFACE_1_BASE 0x1400# define AD9637_INTERFACE_1_IRQ -1# define AD9637_INTERFACE_1_IRQ_INTERRUPT_CONTROLLER_ID -1# define AD9637_INTERFACE_1_NAME "/dev/AD9637_interface_1"# define AD9637_INTERFACE_1_SPAN 1024# define AD9637_INTERFACE_1_TYPE "AD9637_interface"# define ALT_MODULE_CLASS_AD9637_interface_1 AD9637_interface Anyone have suggestions?
