12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoHey billy,
1. Do you have two custom components? 2. Did you make sure (by using qsys and looking at the interfaces tab) you didn't violate the same thing I did? I think you wanna check the "Name" under your s0 module.
