12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoI met the same problem.
And I try the way @m3atwad said: 'changing the interface name to something else on this second peripheral'. but it did not work. The attachment is my component's _hw.tcl~ , and here is part of system.h code generated by using the related sopcinfo# define alt_module_class_ezusb2nios_0 ezusb2nios
# define ezusb2nios_0_base 0x0
# define ezusb2nios_0_irq -1
# define ezusb2nios_0_irq_interrupt_controller_id -1
# define ezusb2nios_0_name "/dev/ezusb2nios_0"
# define ezusb2nios_0_span 1024
# define ezusb2nios_0_type "ezusb2nios"
You can see, the IRQ and IRQ_INTERRUPT_CONTROLLER_ID is still -1. I don't know why
