12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoI don't know of a workaround but my suggestion is to submit a service request and attach the system and custom component to the SR so that the Qsys engineering team can take a look. This is the link to file a service request: http://www.altera.com/mysupport
If this issue started in a certain version you might be able to workaround it by requesting a different .tcl API by editing the .tcl file. Doing so may cause other things to break since the component was created with a newer component editor which used a newer .tcl API so make sure you backup the .tcl file first.
