12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoI use Quartus 13.1 and no bridge in the design. The sender is connected to the NIOSII receiver with automatically assigned numbers. This one is the 4 in Qsys. I checked others IRQ numbers from standard peripherals 0,1,2,3 and 5 are correctly populated in system.h
In one of the Altera's paper they recommend to get inspired with existing components such as jtag_uart which i did. I checked the qsys file and my irq is connected just like the 5 other
