12 years agoCustom ip: can't see IRQ number in system.h
Hello, I'm trying to create a custom component which should generate an interrupt to the NIOS. My problem is that the BSP generate the system.h with no interruption for the component. Qsys ...
12 years agoWhich version of the tools are you using? I remember running into this in the early days of Qsys but I thought these issues were fixed. -1 represents a disconnected interrupt number so assuming you have connected the interrupt sender to the receiver (Nios II) I would have expecting the interrupt number to be populated in system.h instead of -1. Often when I ran into this issue it was when I fed the interrupt through a bridge connection (often to drive it up or down the Qsys system heirarchy). So if you describe the connectivity more I might have a workaround that will work for your system.
