21 years agoCustom instruction
Hi, How can I control the clock enable and other signals for implemented custom instruction with hardware inside the NIOS II (sequential)? Maybe some more examples have Altera (not only combina...
13 years agoThanks. Yeah. I found the way of set it to fixed length, but we should know the number of cycles needed to set that. Therefore better to use variable length and set the done signal when we need the result. I'll try and check.
Thanks for helping.
