21 years agoCustom instruction
Hi, How can I control the clock enable and other signals for implemented custom instruction with hardware inside the NIOS II (sequential)? Maybe some more examples have Altera (not only combina...
13 years agoA lot of the logic of the custom instruction interface can be seen in the RTL viewer.
I suspect that the 'clock enable' is the signal used to stop the cpu during pipeline stalls - so a variable length custom instruction must assert 'done' while clock enable is asserted (but need not otherwise look at it). A fixed length instruction (where the interface counts the clocks for you) will almost certainly have to apply the clock enable to everything.
