22 years agoCustom Instruction
I need help in creating an "External Interface Custom Instruction". Are there any tutorial about it? thanks http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
22 years ago --- Quote Start --- originally posted by matteo@Sep 8 2004, 04:46 AM i need help in creating an "external interface custom instruction".
are there any tutorial about it?
thanks http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/wink.gif --- Quote End --- Did you mean Custom instruction or add hardware to the external interface? http://www.altera.com/literature/ug/ug_nio...instruction.pdf (http://www.altera.com/literature/ug/ug_nios2_custom_instruction.pdf) That tells you everything you need to know. Make sure you carefully read the part about the timing (I usually manage to be off by a clock cycle everytime I make custom hardware http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif ) If you don't know how long your hardware takes to execute use the "done" signal (really wish that was in NIOS I). Cheers
